[gdal-dev] gdal_translate: PLS-00201: identifier must be declared
Lucena, Ivan ivan.lucena at pmldnet.com
Sat Jul 24 02:40:42 EDT 2010
It should work.
You are talking about the create-option INSERT, right?
You would need to add double quotes around the whole options entry therefore you would need to use
single quotes around the RDT name.
I just found a wrong example at [gdal.org/frmt_georaster.html] and I am going to fix that.
It should show single quotes around RDT:
% gdal_translate -of georaster landsat_1.tif georaster:scott/tiger,,landsat,scene \
  -co "INSERT=VALUES(10,'Main building', SDO_GEOR.INIT('RDT', 10))"
Best regards,
Sebastian E. Ovide wrote:
> Hi All,
> gdal_translate works with SDO_GEOR.INIT() but it doesn't with
> any ideas ?
> Sebastian E. Ovide
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
