[gdal-dev] gdal_translate: PLS-00201: identifier must be declared
Sebastian E. Ovide sebastian.ovide at gmail.com
Tue Jul 27 09:15:28 EDT 2010
just to confirm that with single quotes it works well. Thanks
On Sat, Jul 24, 2010 at 7:40 AM, Lucena, Ivan <ivan.lucena at pmldnet.com>wrote:
> Sebastian,
> It should work.
> You are talking about the create-option INSERT, right?
> You would need to add double quotes around the whole options entry
> therefore you would need to use
> single quotes around the RDT name.
> I just found a wrong example at [gdal.org/frmt_georaster.html] and I am
> going to fix that.
> It should show single quotes around RDT:
> % gdal_translate -of georaster landsat_1.tif
> georaster:scott/tiger,,landsat,scene \
>  -co "INSERT=VALUES(10,'Main building', SDO_GEOR.INIT('RDT', 10))"
> Best regards,
> Ivan
> Sebastian E. Ovide wrote:
> > Hi All,
> > gdal_translate works with SDO_GEOR.INIT() but it doesn't with
> > SDO_GEOR.INIT("RDT_MY_TABLE")...
> > any ideas ?
> > Sebastian E. Ovide
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100727/9c9a1e4e/attachment.html
