[gdal-dev] RFC 29: OGR Set Desired Fields
Tamas Szekeres szekerest at gmail.com
Thu Jul 29 15:38:30 EDT 2010
> One that occurs to me is the KML driver, where styles may exist seperately
> from the features; parsing the style KML (and applying all the cascading
> stylesheets, etc.) could be expensive, and excluding it could save
> some processing time in theory.
> In practice, I don't know whether this is the case for the current driver.
Chris,
As far as I can see the OGR KML driver doesn't handle the feature style this
way (while to would indeed be a good addition to expose the KML style as OGR
style). However your requirement may be valid to disable fetching the
feature style from a data source. I would prefer particular enable/disable
methods for each entity regardless of how many special fields are bound to
this entity, like using  OGRFeatureDefn::EnableGeometryColumn(bool)  and
OGRFeatureDefn::EnableFeatureStyle(bool) would be sufficient.
In particular EnableGeometryColumn(false) would implicitly disable each
OGR_GEOMETRY, OGR_GEOM_WKT, OGR_GEOM_AREA mentioned before which are all
derived from the same OGRGeometry of the feature.
Best regards,
Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100729/edc2c64c/attachment.html
