[gdal-dev] Is a way to just get the minimum bounding polygon of just the image.
Iván Sánchez Ortega ivan at sanchezortega.es
Wed Jun 9 09:44:00 EDT 2010
El día Wednesday 09 June 2010 15:24:13, John Mitchell dijo:
> Does anyone know of a tool that will derive the minimum bounding
> polygon of the actual image
Maybe you can start with http://www.gdal.org/gdal_polygonize.html ?
Get some polygons for the black areas, then do a bit of geoprocessing to
calculate the difference between the image bbox and the black polygons.
Iván Sánchez Ortega <ivan at sanchezortega.es>
Un ordenador no es una televisión ni un microondas: es una herramienta
compleja.
