[gdal-dev] Re: Handling nodata values
Chaitanya kumar CH chaitanya.ch at gmail.com
Sat Jun 26 03:53:19 EDT 2010
Nop,
In line 93 in val_repl.py, the default value is taken as of type Byte. For a
quick fix, mention the data type of the raster reported by gdalinfo with the
option -ot to the script. Refer to (
http://trac.osgeo.org/gdal/browser/trunk/gdal/swig/python/samples/val_repl.py#L61)
On Sat, Jun 26, 2010 at 2:11 AM, NopMap <ekkehart at gmx.de> wrote:
> Thank you for your reply. I played around a little bit but without success.
> When I apply val_repl.py to the data, it appears to cut off all the higher
> elevations while the lower areas remain untouched. So the resulting TIF is
> unusable. What could cause this problem?
> gdal_contour seems to recognize the nodata values in the cgiar files, it
> produces a nice shapefile from the unprocessed data.
> But when I run hillshade.exe from the perrygeo demtools on it, it draws a
> huge chasm along the coastline. I have tried to use gdalwarp with
> -srcnodata
> -32768 -dstnodata 0 but this does not have any visible effect.
> What am I doing wrong?
>             Nop
> http://osgeo-org.1803224.n2.nabble.com/Handling-nodata-values-tp5222453p5223678.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100626/f20ffa9a/attachment.html
