[gdal-dev] Using Python-GDAL to retrieve Projection information
    Frank Warmerdam
    warmerdam at pobox.com
    Tue Jun 29 05:46:42 EDT 2010
Kim,
You can use GetProjection() to fetch the coordinate system:
dataset = gdal.Open( input )
projection   = dataset.GetProjection()
The returned value is a string containing the WKT
description of the coordinate system.
Best regards,
On Tue, Jun 29, 2010 at 11:41 AM, Kim Besson <kimbesson1981 at gmail.com> wrote:
> Greetings
> I have been using Python GDAL to retrieve image size (XSize YSize) but now I
> need to retrieve Projection information in order to use in GDALWARP. Has
> anyone has an practical-example on how to use it?
> THanks
> Best regards,
> Kim
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
