[gdal-dev] Raster/vector intersections in PostGIS WKT Raster
Jorge Arévalo jorge.arevalo at deimos-space.com
Tue Jun 29 13:45:51 EDT 2010
Hello,
On Tue, Jun 29, 2010 at 6:46 PM,  <christian.mueller at nvoe.at> wrote:
> Hi, superb job. Congratulations.
> I am a geotools/geoserver developer and one of my jobs is fetching image
> tiles  or the corresponding pyramid tiles from jdbc data sources. Some weeks
> ago, I added support for Oracle Georaster and I want to support WKT
> Georaster too.
> wktraster makes it quite simple to achieve this. Is there any database
> layout you recommend. (A table for the image and one for each pyramid, or
> put all the tiles into one table having an attribute "level",.....).
I'd recommend one table for each separate tiled image. That's, in
fact, one of the ways WKT Raster works, in terms of raster table
arrangement.
> I have seen "gdal2wktraster.py", is this the recommended way to import tiles
> into postgis ?
Yes, this is the way you should use now to import images into PostGIS.
And related with pyramids, if you provide "-l <OVERVIEW_LEVEL>" as
command line option, you will get overview tables named as
o_<LEVEL>_<RASTER_TABLE> and will be populated with GDAL-provided
overviews. Only regular blocking arrangements (see "-k" command line
option too). If you use this "-l" command line option, you'll have to
specify "-V" option too, only the first time you call the script. This
option enables the creation of the needed RASTER_OVERVIEWS table.
Oh, and the gdal2wktraster script generates a SQL output. You'll have
to load into your raster-ready schema.
> What is the table layout created/needed by this utility ?
You'll simply need to "raster-enable" your PostGIS schema by executing
rt_pg/rtpostgis.sql, after compiling and installing WKT Raster. One
additional table, named "RASTER_COLUMNS", will be created in your
schema.
As I said above, if you use "-V" option the first time you execute the
loader script (gdal2wktraster), another new table, named
"RASTER_OVERVIEWS" will be created in your schema too.
This is all you need to start :-)
Comments are welcome, as Pierre said.
> Cheers
> Christian
> Quoting Pierre Racine <Pierre.Racine at sbf.ulaval.ca>:
>> Hi everybody,
>> I'm pleased to announce that you can now do intersections between  rasters
>> and geometries very much like you used to do  geometry/geometry
>> intersections in PostGIS. For this, PostGIS WKT  Raster introduces two new
>> functions to PostGIS:  ST_Intersects(geometry, raster, band) and
>> ST_Intersection(geometry,  raster, band).
>> As its geometry/geometry sister, ST_Intersects(geometry, raster,  band)
>> returns TRUE if the withvalue area of a raster or a raster  tile (nodata
>> value are ignored) intersects a geometry and  ST_Intersection(geometry,
>> raster, band) returns the geometry/value  set of geometries representing the
>> intersection between the geometry  and each polygonized group of pixel
>> sharing a same value from the  raster and its associated value. Example:
>> SELECT polyid,
>>       (ST_Intersection(the_geom, rast)).geom,
>>       (ST_Intersection(the_geom, rast)).val
>> FROM my_polygons, srtm_tiled
>> WHERE ST_Intersects(rast, the_geom)
>> or, a bit more complex, but much faster and returning the same result:
>> SELECT polyid, (gv).geom, (gv).val
>> FROM (SELECT polyid, ST_Intersection(the_geom, rast, 1) AS gv
>>     WHERE ST_Intersects(rast, the_geom)) foo
>> These functions works with any kind of geometry so you can intersect  any
>> road, river, polygons or point layer with your favorite  elevation or land
>> cover raster of any resolution and any size. You  can also load any number
>> of raster in the database with one command  line to constitute a unique
>> table raster coverage of any shape (no  matter if your group of raster do
>> not form a rectangular coverage).
>> You will find a complete tutorial on how to use those two new  functions
>> here:  http://trac.osgeo.org/postgis/wiki/WKTRasterTutorial01. A reference
>>  is available here:
>>  http://postgis.refractions.net/documentation/manual-svn/RT_reference.html
>>  and chapter 13 of "PostGIS in Action" is also a very good  introduction to
>> WKT Raster.
>> Compilation and installation info are available in the project home  page:
>> These features are the result of two years of collaboration between  many
>> people and companies interested in bringing raster into  PostGIS. I would
>> like to thanks particularly Steve Cumming who  initially made all this
>> possible, Sandro Santilli who wrote the base  code, Mateusz Loskot who wrote
>> the Python loader, Jorge Arevalo who  wrote the GDAL driver and
>> ST_DumpAsPolygons(), Regina and Leo Obe  who are doing so many things and
>> believed in the project from the  beginning by adding a chapter about WKT
>> Raster in "PostGIS in  Action" and also David Zwarg who wrote most of the
>> setter functions.
>> This is the first step toward a first complete raster/vector  analysis and
>> manipulation SQL API. We hope to make of PostGIS with  WKT Raster the most
>> powerful and complete GIS analysis and  manipulation high level language
>> ever (!!!). WKT Raster should  normally be totally integrated into PostGIS
>> in PostGIS release 2.0.  Upcoming functions should include ST_Reclass,
>> ST_Clip, ST_AsRaster,  ST_Resample.
>> Let us know your need and your experience with WKT Raster.
>> Thanks,
>> Pierre Racine
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
> This message was sent using IMP, the Internet Messaging Program.
Jorge Arévalo
DEIMOS Space
Internet & Mobilty Division
Ronda de Poniente 19. Edificio Fiteni VI, portal 2, 2º
28760 Tres Cantos (Madrid)
Tel: +34 91 806 34 50 - ext: 155
http://gis4free.wordpress.com
