[gdal-dev] Commit r19248
Even Rouault even.rouault at mines-paris.org
Mon Mar 29 13:50:11 EDT 2010
Andrey,
r19248 introduce Python specific code in general .i files. The consequence is
that it breaks the Perl bindings (see
http://buildbot.osgeo.org:8500/builders/telascience-quick/builds/312/steps/perl-make/logs/stdio).
It also breaks Python3 compatibility as PyString_FromStringAndSize and
PyString_AsString aren't available (though this could be fixed easily by
using PyBytes_FromStringAndSize and PyBytes_AsString with a #if
PY_VERSION_HEX >= 0x03000000)
I think the new implementation should be done only inside a #if
defined(SWIGPYTHON) I guess, and the old implementation preserved for other
binding languages.
Best regards
Even
