[gdal-dev] how to set raster bands with gdalwarp
easyl easy.lin at gmail.com
Tue Mar 30 09:40:32 EDT 2010
I am making map tiles from a PNG (in RGBA color) with following commands.
gdal_translate -of VRT -a_srs EPSG:4326 -gcp ... source.png source.vrt
gdalwarp -of VRT -s_srs EPSG:4326 -t_srs EPSG:900913 source.vrt
source_web.vrt
gdal2tiles -p mercator -z 2-11 -w google source_web.vrt
By the gdalwarp step, the source_web.vrt is generated with undesired raster
bands as following
<VRTDataset>
  <VRTRasterBand dataType="Byte" band="1" subClass="VRTWarpedRasterBand"/>
  <VRTRasterBand dataType="Byte" band="2" subClass="VRTWarpedRasterBand"/>
  <VRTRasterBand dataType="Byte" band="3" subClass="VRTWarpedRasterBand"/>
  <VRTRasterBand dataType="Byte" band="4" subClass="VRTWarpedRasterBand"/>
    <BandList>
      <BandMapping src="1" dst="1"/>
      <BandMapping src="2" dst="2"/>
      <BandMapping src="3" dst="3"/>
    </BandList>
    <SrcAlphaBand>4</SrcAlphaBand>
  </GDALWarpOptions>
</VRTDataset>
How can I use gdalwarp or other utilities to let vrt generated with RGBA
bands as following.
<VRTDataset>
  <VRTRasterBand dataType="Byte" band="1" subClass="VRTWarpedRasterBand">
    <Metadata/>
    <ColorInterp>Red</ColorInterp>
  </VRTRasterBand>
  <VRTRasterBand dataType="Byte" band="2" subClass="VRTWarpedRasterBand">
    <Metadata/>
    <ColorInterp>Green</ColorInterp>
  </VRTRasterBand>
  <VRTRasterBand dataType="Byte" band="3" subClass="VRTWarpedRasterBand">
    <Metadata/>
    <ColorInterp>Blue</ColorInterp>
  </VRTRasterBand>
  <VRTRasterBand dataType="Byte" band="4" subClass="VRTWarpedRasterBand">
    <Metadata/>
    <ColorInterp>Alpha</ColorInterp>
  </VRTRasterBand>
  <GDALWarpOptions>
    <BandList>
      <BandMapping src="4" dst="4"/>
    </BandList>
  </GDALWarpOptions>
</VRTDataset>
View this message in context: http://n2.nabble.com/how-to-set-raster-bands-with-gdalwarp-tp4824518p4824518.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
