[gdal-dev] Will gdalinfo generate the pam .aux.xml files?
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri May 7 01:43:53 EDT 2010
Jared,
For gdalinfo to create .aux.xml files, you just need to force it to compute
some metadata not stored in the file.
On Fri, May 7, 2010 at 2:39 AM, Rubin, Jared <JARED.RUBIN at saic.com> wrote:
>  I am using gdal-1.6.2 (version not important) and would like for gdalinfo
> to generate  .aux.xml files  for NITF files that I have on disk, is this
> possible?
> If this is possible, will gdalinfo just load an  image.nitf.aux.xml file
> instead of image.nitf?
> Thanks
> Jared
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100507/caa845bf/attachment.html
