[gdal-dev] Compilation problems on CentOS 5
Fri May 7 11:36:28 EDT 2010
Peter Hopfgartner wrote:
> Hello
> I'm trying to compile GDAL 1.7.2 on my CentOS 5.4, 64 bit box. Configure
> is basically "enable Oracle, disable almost anything else":
> ./configure --without-php --without-python --without-perl --with-oci
> --with-ecw --with-libtiff=internal --with-geotiff=internal
> --with-netcdf=no --with-cfitsio=no
> Compilation stops with:
> libtool: link: g++ .libs/gdalinfo.o
> -o .libs/gdalinfo  /home/rpmbuild/tmp/gdal-1.7.2/.libs/libgdal.so
> -Wl,-rpath -Wl,/usr/local/lib
> /home/rpmbuild/tmp/gdal-1.7.2/.libs/libgdal.so: undefined reference to
> `XML_StopParser'
> collect2: ld returned 1 exit status
> make[1]: *** [gdalinfo] Error 1
> make[1]: Leaving directory `/home/rpmbuild/tmp/gdal-1.7.2/apps'
> make: *** [apps-target] Error 2
> Where should the symbol "XML_StopParser" come from?
Peter,
This is part of the expat library.  You could try configuring --without-expat
to doing a clean build.  I'm guessing you have a version of expat that is too
old, or too new and lacks XML_StopParser.  If you could provide version
information it might make it possible for us to dig further into the issue.
Best regards,
