[gdal-dev] Will gdalinfo generate the pam .aux.xml files?
Chaitanya kumar CH chaitanya.ch at gmail.com
Mon May 10 14:40:55 EDT 2010
Check if gdalinfo creates the xml files when used with the -stats option on
your images. If it does, run it on all the images. I don't think there is a
much quicker way. The computation of the statistics is the bottleneck here.
On Mon, May 10, 2010 at 11:43 PM, Rubin, Jared <JARED.RUBIN at saic.com> wrote:
>  That sucks. I have hundreds of images on disk and would like to just have
> the xml file for each file so that I can just do fast "greps" for specfic
> tags.
> What is the reason behind this design choice? Also are any of the gdalinfo
> calls quick?
> Jared
> -----Original Message-----
> From: Chaitanya kumar CH [mailto:chaitanya.ch at gmail.com<chaitanya.ch at gmail.com>
> Sent: Thu 5/6/2010 10:43 PM
> To: Rubin, Jared
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] Will gdalinfo generate the pam .aux.xml files?
> Jared,
> For gdalinfo to create .aux.xml files, you just need to force it to compute
> some metadata not stored in the file.
> On Fri, May 7, 2010 at 2:39 AM, Rubin, Jared <JARED.RUBIN at saic.com> wrote:
> >  I am using gdal-1.6.2 (version not important) and would like for
> gdalinfo
> > to generate  .aux.xml files  for NITF files that I have on disk, is this
> > possible?
> > If this is possible, will gdalinfo just load an  image.nitf.aux.xml file
> > instead of image.nitf?
> > Thanks
> > Jared
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> /t?a???nj?/ /k?m?r/
> +91-9848167848
> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9848167848
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100511/1ab5219f/attachment.html
