[gdal-dev] Python (2.6.5) GDAL module will not install with easy_install
Brice Lambi lambi at ucar.edu
Tue May 11 13:19:29 EDT 2010
What is your python path?
# python
>>> import sys
>>> sys.path
What does that say?  It might have linked against the wrong version of
gdal or it might be finding another gdal library in your path.  If you
are using the default python (/usr/bin/python) it is probably finding
something in /usr/lib before /opt/GEOSR/local.
Allen Rongone wrote:
> Brice,
>     I think I was using the tarball specific to the python module. I
> think I downloaded the correct one now - gdal-1.7.2.tar.gz
>     I ran the configure script as such:
>     # ./configure --prefix=/opt/GOESR/local --with-python
>     Then a make
>     # make
>     Then a make install
>     # make install
>     Everything seemed fine until I tried to import the module in python.
> I got this when I tried:
>> [root at psd14 gdal-1.7.2]# python
>> Python 2.6.5 (r265:79063, May  3 2010, 14:23:56)
>> [GCC 4.1.2 20080704 (Red Hat 4.1.2-46)] on linux2
>> Type "help", "copyright", "credits" or "license" for more information.
>> >>> from osgeo import gdal
>> Traceback (most recent call last):
>>   File "<stdin>", line 1, in <module>
>>   File
>> "/opt/GOESR/local/lib/python2.6/site-packages/GDAL-1.7.2-py2.6-linux-x86_64.egg/osgeo/__init__.py",
>> line 21, in <module>
>>     _gdal = swig_import_helper()
>>   File
>> line 17, in swig_import_helper
>>     _mod = imp.load_module('_gdal', fp, pathname, description)
>> ImportError:
>> /opt/GOESR/local/lib/python2.6/site-packages/GDAL-1.7.2-py2.6-linux-x86_64.egg/osgeo/_gdal.so:
>> undefined symbol: GDALGetMaskFlags
> Any ideas why I'm getting the ImportError with the undefined symbol?
> Thank you very much for your help,
> Allen Rongone
> On May 6, 2010, at 12:47 PM, Brice Lambi wrote:
>> Hi Allen,
>> Are you compiling from source?  When I install gdal python I just go
>> into the swig/python directory and run 'python setup.py install'.  This
>> should work.  The steps I take:
>> tar zxvf gdal-1.7.1.tar.gz
>> cd gdal-1.7.1
>> ./configure --prefix=/usr
>> make
>> make install #run as root
>> cd swig/python
>> python setup.py install #run as root
>> Hope this helps.
>> Cheers,
>> Brice
>>> Hello All,
>>>    New here so don't beat me up to bad.
>>>    I'm trying to get the GDAL module to install on a Red Hat Enterprise
>>> Linux 5.4 64-bit workstation running Python 2.6.5.
>>>    I have installed the setuptools 0.6c11 and am using easy_install
>>>    My gdal-config is in /usr/bin, however, when I run easy_install GDAL
>>> it complains that it "Could not run gdal-config!!!" and then contiues on
>>> complaining about a bunch of stuff not
>>>    being declared.
>>>    I can not find the setup.py to edit and change the location of
>>> gdal-config. easy_install must clean everything up if it fails.
>>>    Does anyone know how to get this to work or will we have to do
>>> without GDAL in python?
>>> Thanks for any help,
>>> Allen
>>> I've included everything I thought pertinent below:
>>> [root at psd14 ~]# uname -a
>>> Linux psd14.aer.com 2.6.18-164.15.1.el5 #1 SMP Mon Mar 1 10:56:08 EST
>>> 2010 x86_64 x86_64 x86_64 GNU/Linux
>>> [root at psd14 ~]# python
>>> KeyboardInterrupt
>>> [root at psd14 ~]# which gdal-config
>>> /usr/bin/gdal-config
>>> [root at psd14 ~]# easy_install GDAL
>>> Searching for GDAL
>>> Reading http://pypi.python.org/simple/GDAL/
>>> Reading http://www.gdal.org
>>> Best match: GDAL 1.7.1
>>> Downloading
>>> http://pypi.python.org/packages/source/G/GDAL/GDAL-1.7.1.tar.gz#md5=38b838d528b309a28a3aa24d4fcef3cd
>>> Processing GDAL-1.7.1.tar.gz
>>> Running GDAL-1.7.1/setup.py -q bdist_egg --dist-dir
>>> /tmp/easy_install-eKZHzW/GDAL-1.7.1/egg-dist-tmp-siVuDI
>>> Could not run gdal-config!!!!
>>> cc1plus: warning: command line option "-Wstrict-prototypes" is valid for
>>> Ada/C/ObjC but not for C++
>>> extensions/gdal_wrap.cpp: In function $(B!F(Bint
>>> GDALDriverShadow_Rename(GDALDriverShadow*, const char*, const
>>> char*)$(B!G(B:
>>> extensions/gdal_wrap.cpp:3371: error:
>>> $(B!F(BGDALRenameDataset$(B!G(B was not declared in this scope
>>> extensions/gdal_wrap.cpp: In function $(B!F(BCPLErr
>>> GDALDatasetShadow_CreateMaskBand(GDALDatasetShadow*, int)$(B!G(B:
>>> extensions/gdal_wrap.cpp:3744: error:
>>> $(B!F(BGDALCreateDatasetMaskBand$(B!G(B was not declared in this
>>> scope
>>> extensions/gdal_wrap.cpp: In function $(B!F(Bchar**
>>> GDALDatasetShadow_GetFileList(GDALDatasetShadow*)$(B!G(B:
>>> extensions/gdal_wrap.cpp:3747: error: $(B!F(BGDALGetFileList$(B!G(B
>>> extensions/gdal_wrap.cpp: In function $(B!F(BGDALRasterBandShadow*
>>> GDALRasterBandShadow_GetMaskBand(GDALRasterBandShadow*)$(B!G(B:
>>> extensions/gdal_wrap.cpp:4077: error: $(B!F(BGDALGetMaskBand$(B!G(B
>>> GDALRasterBandShadow_GetMaskFlags(GDALRasterBandShadow*)$(B!G(B:
>>> extensions/gdal_wrap.cpp:4080: error: $(B!F(BGDALGetMaskFlags$(B!G(B
>>> GDALRasterBandShadow_CreateMaskBand(GDALRasterBandShadow*,
>>> int)$(B!G(B:
>>> extensions/gdal_wrap.cpp:4083: error:
>>> $(B!F(BGDALCreateMaskBand$(B!G(B was not declared in this scope
>>> extensions/gdal_wrap.cpp: In function $(B!F(Bvoid
>>> GDALColorTableShadow_CreateColorRamp(GDALColorTableShadow*, int, const
>>> GDALColorEntry*, int, const GDALColorEntry*)$(B!G(B:
>>> extensions/gdal_wrap.cpp:4147: error:
>>> $(B!F(BGDALCreateColorRamp$(B!G(B was not declared in this scope
>>> ComputeProximity(GDALRasterBandShadow*, GDALRasterBandShadow*, char**,
>>> int (*)(double, const char*, void*), void*)$(B!G(B:
>>> extensions/gdal_wrap.cpp:4306: error:
>>> $(B!F(BGDALComputeProximity$(B!G(B was not declared in this scope
>>> RasterizeLayer(GDALDatasetShadow*, int, int*, OGRLayerShadow*, void*,
>>> void*, int, double*, char**, int (*)(double, const char*, void*),
>>> void*)$(B!G(B:
>>> extensions/gdal_wrap.cpp:4342: error:
>>> $(B!F(BGDALRasterizeLayers$(B!G(B was not declared in this scope
>>> Polygonize(GDALRasterBandShadow*, GDALRasterBandShadow*,
>>> OGRLayerShadow*, int, char**, int (*)(double, const char*, void*),
>>> void*)$(B!G(B:
>>> extensions/gdal_wrap.cpp:4362: error: $(B!F(BGDALPolygonize$(B!G(B
>>> FillNodata(GDALRasterBandShadow*, GDALRasterBandShadow*, double, int,
>>> char**, int (*)(double, const char*, void*), void*)$(B!G(B:
>>> extensions/gdal_wrap.cpp:4378: error: $(B!F(BGDALFillNodata$(B!G(B
>>> SieveFilter(GDALRasterBandShadow*, GDALRasterBandShadow*,
>>> GDALRasterBandShadow*, int, int, char**, int (*)(double, const char*,
>>> extensions/gdal_wrap.cpp:4394: error: $(B!F(BGDALSieveFilter$(B!G(B
>>> RegenerateOverviews(GDALRasterBandShadow*, int, GDALRasterBandShadow**,
>>> const char*, int (*)(double, const char*, void*), void*)$(B!G(B:
>>> extensions/gdal_wrap.cpp:4408: error: invalid conversion from
>>> $(B!F(BGDALRasterBandShadow*$(B!G(B to
>>> $(B!F(BGDALRasterBand*$(B!G
>>> (Bextensions/gdal_wrap.cpp:4408: error:   initializing argument 1
>>> of $(B!F(BCPLErr GDALRegenerateOverviews(GDALRasterBand*, int,
>>> GDALRasterBand**, const char*, int (*)(double, const char*, void*),
>>> void*)$(B!G
>>> (Bextensions/gdal_wrap.cpp:4408: error: invalid conversion from
>>> $(B!F(BGDALRasterBandShadow**$(B!G(B to
>>> $(B!F(BGDALRasterBand**$(B!G
>>> (Bextensions/gdal_wrap.cpp:4408: error:   initializing argument 3
>>> void*)$(B!G
>>> (Bextensions/gdal_wrap.cpp: In function $(B!F(Bint
>>> RegenerateOverview(GDALRasterBandShadow*, GDALRasterBandShadow*, const
>>> extensions/gdal_wrap.cpp:4421: error: invalid conversion from
>>> (Bextensions/gdal_wrap.cpp:4421: error:   initializing argument 1
>>> void*)$(B!G
>>> (Bextensions/gdal_wrap.cpp:4421: error: invalid conversion from
>>> (Bextensions/gdal_wrap.cpp:4421: error:   initializing argument 3
>>> void*)$(B!G
>>> $(B!F(BGDALTransformerInfoShadow*
>>> new_GDALTransformerInfoShadow(GDALDatasetShadow*,
>>> GDALDatasetShadow*, char**)$(B!G(B:
>>> extensions/gdal_wrap.cpp:4445: error:
>>> $(B!F(BGDALCreateGenImgProjTransformer2$(B!G(B was not declared in
>>> this scope
>>> GDALTransformerInfoShadow_TransformPoint__SWIG_0(GDALTransformerInfoShadow*,
>>> int, double*)$(B!G(B:
>>> extensions/gdal_wrap.cpp:4456: error:
>>> $(B!F(BGDALUseTransformer$(B!G(B was not declared in this scope
>>> GDALTransformerInfoShadow_TransformPoint__SWIG_1(GDALTransformerInfoShadow*,
>>> double*, int, double, double, double)$(B!G(B:
>>> extensions/gdal_wrap.cpp:4468: error:
>>> GDALTransformerInfoShadow_TransformPoints(GDALTransformerInfoShadow*,
>>> int, int, double*, double*, double*, int*)$(B!G(B:
>>> extensions/gdal_wrap.cpp:4550: error:
>>> extensions/gdal_wrap.cpp: In function $(B!F(BGDALDriverShadow*
>>> IdentifyDriver(const char*, char**)$(B!G(B:
>>> extensions/gdal_wrap.cpp:4661: error:
>>> $(B!F(BGDALIdentifyDriver$(B!G(B was not declared in this scope
>>> extensions/gdal_wrap.cpp: In function $(B!F(BPyObject*
>>> _wrap_ReadDir(PyObject*, PyObject*)$(B!G(B:
>>> extensions/gdal_wrap.cpp:5255: error: $(B!F(BVSIReadDir$(B!G(B was
>>> error: Setup script exited with error: command 'gcc' failed with exit
>>> status 1
>>> [root at psd14 ~]#
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
