[gdal-dev] gdal2tiles output packed as kmz doesn't load in Google
	Earth
    Jeffrey Warren
    jeff at unterbahn.com
    Mon May 17 11:08:59 EDT 2010
Hi, I'm probably missing something obvious, but I tried packing an output
directory from gdal2tiles -k (generating the doc.kml) and while the kml
loads, and all the sub-kmls load (i.e. 11/1401/2322.kml etc.) when I
compress them into a zip and rename kmz, the images don't load.
Google Earth doesn't seem to have an error console but it does actually
follow the doc.kml network links, and finds the sub-kmls. It just doesn't
find the images.
Am I missing something? the generated doc.kml uses relative paths and I've
read the docs...
anyways the files are here, along with the link to the root doc.kml. Could
anyone take a look and help me out here?
maps.grassrootsmapping.org/chandeleur-may8-plane.kmz
maps.grassrootsmapping.org/chandeleur-may8-plane/doc.kml
maps.grassrootsmapping.org/may-9-chandeleur-balloon.kmz
maps.grassrootsmapping.org/may-9-chandeleur-balloon/doc.kml
For reference, these two tilesets also have absolute path .kml files here,
which load properly in GE:
maps.grassrootsmapping.org/chandeleur-may8-plane.kml
maps.grassrootsmapping.org/may-9-chandeleur-balloon.kml
Thanks for any tips/suggestions!
Best,
Jeff
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20100517/8a56e617/attachment.html
