[gdal-dev] DXF Writer and labels: encoding, angle and anchor position?
Andreas Neumann a.neumann at carto.net
Mon Nov 1 10:19:22 EDT 2010
Again some question on the dxf-writer, now with regards to labels:
* some of my special characters don't display correctly, e.g. the Unicode
2030 sign (german Promille sign) doesn't display (neither in the FME
viewer nor in Autocad Design Review) - some other "strange characters" are
displayed instead. Do I have to set an encoding for the target dxf? My
source Postgis table is in UTF-8.
* should label angle work? (in my case it doesn't)
* should anchor position work?
Here is an example OGR feature-style that I am testing:
LABEL(f:"Cadastra Cn,Arial",s:1.5g,t:"PVC 150 -6.96-",c:#FF0000,a:72,p:3)
In the above example, the label angle does not work - I am unsure about
the anchor position.
Thanks for any hints or info, if any of the above should be implemented or
if I am doing something wrong in my OGR feature-styling.
Andreas
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
