[gdal-dev] getting a new gcs.csv
Anders Moe anders.moe at geocap.no
Wed Nov 10 03:49:15 EST 2010
Andrea
I've had my share of problems finding the *.cvs files too, but maybe you
could try :
1) Executing from the location of the ogr2ogr.exe utility
2) Having the *.cvs files in that directory
3) Having the GDAL_DATA environment variable set to the same directory.
Cheers,
Anders
On Tue, Nov 9, 2010 at 6:57 PM, Andrea Peri 2007 <aperi2007 at gmail.com>wrote:
> Frank,
> thx for link.
> I take the last gcs.csv and pcs.csv.
> I verify that in the new pcs.csv there is EPSG:3003 (it is projected)
> but even now ogr2ogr.exe still report me
> the epsg pcs/gcs code 3003 not found.
> seem that ogr2ogr is not using the pcs.csv file .
> Thx,
> Andrea.
> Il 09/11/2010 18:13, Frank Warmerdam ha scritto:
>  Andrea Peri 2007 wrote:
>>> Hi,
>>> I'm trying to use the ogr2ogr.exe compiled with VC++ .
>>> running ogr2ogr it give me this message:
>>> ERROR 4: Unable to open EPSG support file gcs.csv
>>> so I retrieve a gcs.csv file from FWTools2.4.7 and copy it in the same
>>> folder of ogr2ogr.
>>> after this copy.
>>> The new message from ogr2ogr is this:
>>> "error 6: epsg pcs/gcs code 3003 not found in EPSG support files. Is this
>>> a valid EPSG"
>>> I check to the www.epsg.org that EPSG:3003 is a valid epsg coordinate
>>> system.
>>> So I think perhaps the  gcs.csv file of fwtool is old.
>>> There is available a new version of gcs.csv ?
>> Andrea,
>> The latest gcs.csv and pcs.csv can be found at:
>>  http://svn.osgeo.org/gdal/trunk/gdal/data
>> They should work fine with older GDAL's.
>> Best regards,
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
________________________________________________________
Anders Moe
Managing Director
Geocap
w: +47 22 95 56 63
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101110/0c4b8f04/attachment.html
