[gdal-dev] Something is broken on Win install
Sat Nov 13 13:02:01 EST 2010
Joaquim Luis wrote:
>         cd ..\apps
>         nmake /nologo /f makefile.vc install
>         copy *.exe ..\WIN64\bin
> gdaladdo.exe
> The system cannot find the path specified.
>         0 file(s) copied.
> NMAKE : fatal error U1077: 'copy' : return code '0x1'
> Stop.
> The problem seams to be that it's trying to put things in
> ..\WIN64\bin
> which I never told it to do. My nmake.opt has
> !IFDEF WIN64
> GDAL_HOME = "C:\programs\GDALtrunk\gdal\compileds\VC10_64"
> !ELSE
> !IF $(MSVC_VER) >= 1600
> GDAL_HOME = "C:\programs\GDALtrunk\gdal\compileds\VC10_32"
Joaquim,
I don't know why this is happening in your case. I tried a clean
build and install on windows (32 bit) from trunk and had no problem.
Best regards,
