[gdal-dev] error compiling gdal 1.6.3 in rhel 5 64bits
Thu Nov 18 10:45:49 EST 2010
javiricca wrote:
> Hello,
> I'll trying to compile gdal in rhel 5 64 bits and I've getting some errors.
 > gdal_wrap.cpp:1067: error: ‘zend_property_reference’ no se declaró en este
ámbito
> How can I solve this problem? Is possible to solve it with another version
> of gdal or installing other libraries.
> Thanks in advance
Javiricca,
Presumably this is a problem with the php bindings.  The php bindings are
not maintained at this time and it is unclear to what extent they work or
don't work.  So my suggestion is that they should not be part of your
packaging effort unless you know they work in a useful way.
Best regards,
