[gdal-dev] Re: GDAL JAVA problem
Even Rouault even.rouault at mines-paris.org
Wed Oct 13 05:17:05 EDT 2010
Sagar,
this is normally just a matter of having all the needed .so (libgdal.so and the
4 JNI .so) in your LD_LIBRARY_PATH and gdal.jar in your java classpath.
I'd encourage you to try on the command line first.
See http://trac.osgeo.org/gdal/wiki/GdalOgrInJavaBuildInstructionsUnix
