[gdal-dev] geoPDF file "not recognized as a supported format" by
GDAL1.8dev ?
Boris Dev
boris.dev at gmail.com
Thu Oct 14 15:24:38 EDT 2010
A GDAL doc <http://www.gdal.org/frmt_pdf.html> says GDAL1.8 handles
geospatial PDF file (which I assume are the same as geoPDF topo files of the
USGS).
The problem is that after compiling GDAL1.8 from source GDAL doesn't
recognize my geoPDF file.
When I try both of the following:
$gdalinfo my_geopdf.pdf
$gdal_translate my_geopdf.pdf
It returns:
ERROR 4: 'my_geopdf.pdf' not recognized as a supported format"
When compiling GDAL and POPPLER (which is also needed for this problem) I
made sure to do the following:
gdal$./configure --with-poppler=yes --with-python
poppler$./configure --enable-xpdf-headers
...any suggestions on where I am going wrong with this?
I am new to using GDAL.
My final objective to to extact the geoPDF images as jpegs and somehow
extract the latitude/longitude bounding box information of the image so I
can create KMLs.
THANKS!!
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20101014/86bef919/attachment.html
