[gdal-dev] mod_python issue with libtiff
Andreas Neumann a.neumann at carto.net
Fri Oct 15 11:26:13 EDT 2010
I recently upgraded my gdal version to the recent SVN version. The
command-line tools work fine, but my python scripts inside Apache
mod_python fail with the following error:
ERROR 1: WARNING ! libtiff version mismatch : You're linking against
libtiff 3.X but GDAL has been compiled against libtiff >= 4.0.0
[Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] mod_python
(pid=2117, interpreter='srv139.stadt-uster.ch', phase='PythonHandler',
handler='mod_python.publisher'): Application error
[Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] ServerName:
[Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] DocumentRoot:
'/home/www/www/'
[Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] URI:
'/geodatenshop/extract_meta.py/raster'
[Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] Location: None
[Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] Directory: '/'
[Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] Filename:
'/home/www/www/geodatenshop/extract_meta.py'
[Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] PathInfo: '/raster'
[Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] Traceback (most
recent call last):
"/usr/lib/python2.6/dist-packages/mod_python/importer.py", line 1537, in
HandlerDispatch\n    default=default_handler, arg=req,
silent=hlist.silent)
"/usr/lib/python2.6/dist-packages/mod_python/importer.py", line 1229, in
_process_target\n    result = _execute_target(config, req, object, arg)
"/usr/lib/python2.6/dist-packages/mod_python/importer.py", line 1128, in
_execute_target\n    result = object(arg)
"/usr/lib/python2.6/dist-packages/mod_python/publisher.py", line 213, in
handler\n    published = publish_object(req, object)
"/usr/lib/python2.6/dist-packages/mod_python/publisher.py", line 425, in
publish_object\n    return publish_object(req,util.apply_fs_data(object,
req.form, req=req))
"/usr/lib/python2.6/dist-packages/mod_python/util.py", line 554, in
apply_fs_data\n    return object(**args)
"/home/www/www/geodatenshop/extract_meta.py", line 18, in raster\n
req.write('\\t<driver>'+dataset.GetDriver().ShortName+'/'+dataset.GetDriver().LongName+'</driver>\\n')
[Fri Oct 15 17:03:22 2010] [error] [client 10.63.238.198] AttributeError:
'NoneType' object has no attribute 'GetDriver'
I set the libtiff to "internal" in the configure options before the compile.
I don't understand why the mod_python scripts link to libtiff 3.x. Why are
the commandline tools (gdal-info, gdal-translate, gdal_merge.py, etc.)
working fine, but the scripts inside mod_python do not.
Both are using python2.6.
Thank you very much for any pointers or hints on what may be wrong in my
configuration.
Andreas
Andreas Neumann
http://www.carto.net/neumann/
http://www.svgopen.org/
