[gdal-dev] Re: Copy only georeference between two images
christian.mueller at nvoe.at christian.mueller at nvoe.at
Mon Sep 13 11:20:16 EDT 2010
And what is the output of the second image ?
Quoting canduc17 <candini at meeo.it>:
> My case is the first one: with gdalinfo on one of my images I obtain:
> Driver: GTiff/GeoTIFF
> Files: AVN_CLS57_ALAV2A127252720_20080614_20100906.tif
> Size is 8505, 8378
> Coordinate System is:
> PROJCS["WGS 84 / UTM zone 31N",
>     GEOGCS["WGS 84",
>         DATUM["WGS_1984",
>             SPHEROID["WGS 84",6378137,298.2572235630016,
>                 AUTHORITY["EPSG","7030"]],
>             AUTHORITY["EPSG","6326"]],
>         PRIMEM["Greenwich",0],
>         UNIT["degree",0.0174532925199433],
>         AUTHORITY["EPSG","4326"]],
>     PROJECTION["Transverse_Mercator"],
>     PARAMETER["latitude_of_origin",0],
>     PARAMETER["central_meridian",3],
>     PARAMETER["scale_factor",0.9996],
>     PARAMETER["false_easting",500000],
>     PARAMETER["false_northing",0],
>     UNIT["metre",1,
>         AUTHORITY["EPSG","9001"]],
>     AUTHORITY["EPSG","32631"]]
> Origin = (646644.437500000000000,4872539.500000000000000)
> Pixel Size = (10.000000000000000,-10.000000000000000)
> Metadata:
>   AREA_OR_POINT=Area
> Image Structure Metadata:
>   COMPRESSION=LZW
>   INTERLEAVE=BAND
> Corner Coordinates:
> Upper Left  (  646644.438, 4872539.500) (  4d49'43.67"E, 43d59'28.91"N)
> Lower Left  (  646644.438, 4788759.500) (  4d48'21.90"E, 43d14'14.57"N)
> Upper Right (  731694.438, 4872539.500) (  5d53'18.11"E, 43d58'10.13"N)
> Lower Right (  731694.438, 4788759.500) (  5d51'9.09"E, 43d12'57.82"N)
> Center      (  689169.438, 4830649.500) (  5d20'38.21"E, 43d36'17.27"N)
> http://osgeo-org.1803224.n2.nabble.com/Copy-only-georeference-between-two-images-tp5526582p5526623.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
This message was sent using IMP, the Internet Messaging Program.
