[gdal-dev] Mask and GEOTiff
canduc17 candini at meeo.it
Thu Apr 28 03:30:02 EDT 2011
Hi everyone.
Is there a way to crop a GEOTiff image using a Mask of the same dimension?
For example, a mask with a filled circle: every pixel inside the circle is 1
and the others are 0.
I would like to obtain a new GEOTiff with only the pixel inside the circle
visible and the other set to 0.
Is that possible with tools like gdal_translate or other ones?
Thanks in advance!
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Mask-and-GEOTiff-tp6312284p6312284.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
