[gdal-dev] Re: gdalwarp capability to output as netCDF format
Chaitanya kumar CH chaitanya.ch at gmail.com
Wed Aug 24 05:09:10 EDT 2011
Hendy,
Currently, there are no plans to implement the Create method for the netCDF
driver. You can formally request for it by creating a ticket in the gdal
trac page [1].
To implement the method yourselves, you have to look at the current driver
page[2] and the driver implementation tutorial page[3].
[1]: http://trac.osgeo.org/gdal/
[2]: http://www.gdal.org/frmt_netcdf.html
[3]: http://www.gdal.org/gdal_drivertut.html
On Wed, Aug 24, 2011 at 2:20 PM, Hendy Sumanto <hsumanto at vpac.org> wrote:
> I probably should change the question to this to make it clearer.
> Does anyone know whether there is plan to implement Create method for
> netCDF driver as currently it is only support only CreateCopy method?
> If no, could someone please describe what steps would be involved to add
> this method to the netCDF driver as I am pretty new to GDAL.
> Thanks.
> Regards,
> Hendy
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110824/3681fcf4/attachment.html
