[gdal-dev] Call to users and devs - ESRI .prj files needed for testing
Etienne Tourigny etourigny.dev at gmail.com
Fri Dec 2 11:25:00 EST 2011
On Fri, Dec 2, 2011 at 2:00 PM, Martin Daly <Martin.Daly at cadcorp.com> wrote:
>> Martin, thanks for this reference!
>> It seems that the dattrans.htm file contains datum transformations used
>> by ESRI, with a number of methods.
>> Would it make any sense to use that information (using a new derived
>> .csv file) to add TOWGS84 parameters to ESRI WKT definitions, instead
>> of using the ones defined in gcs.csv?
> I couldn't really say; it would depend on what you are trying to achieve.
> However, it is my understanding that you are safe in assuming that *if* the WKT matches one of these standard ones, *and* the ESRI code matches an EPSG one, that the EPSG definition is being used (or at least intended). *If* I am right then you should be able to use the GDAL definition directly, instead of trying to morph one to the other.
I'm not sure I understand.  " one of these standard ones" refers to
the WKT definitions by ESRI?  In that case, we could compare the given
WKT (in .prj file), and lookup the associated ESRI code, matching it
to EPSG code.
Are you suggesting that we could use the GDAL definition (as derived
from importFromEPSG()), without doing the morphFromESRI in this case?
> Martin
> Cadcorp is a trading name of Computer Aided Development Corporation Limited; registered in England;
> number: 1955756. Registered office : Sterling Court, Norton Road, Stevenage, Herts SG1 2JY
> This email is confidential and may be privileged and should not be used, read
> or copied by anyone who is not the original intended recipient. If you have
> received this email in error please inform the sender and delete it from
> your mailbox or any other storage mechanism. Unless specifically stated,
> nothing in this email constitutes an offer by Cadcorp and Cadcorp does not
> warrant that any information contained in this email is accurate.
> Cadcorp cannot accept liability for any statements made which are clearly the
> sender's own and not expressly made on behalf of Cadcorp or one of its agents.
> Please rely on your own virus check. No responsibility is taken by Cadcorp
> for any damage arising out of any bug or virus infection.
