[gdal-dev] how to get gis layer information from GeoPDF (e.g. retrieve building polygon coordinates)
Jared Rubin JARED.RUBIN at saic.com
Fri Dec 2 17:19:10 EST 2011
Even,
Would it be possible to do an ogr driver to get the vector features (I guess
similar to shape files? Or maybe update the pdf driver to dump  each
indivual vector feature into gdal metadata?
I'm not too familiar with GeoPDF, I just have seen how Adobe allows for
selection of specific vectors/objects/etc.
thanks
Jared
On 12/2/11 3:14 PM, "Even Rouault" <even.rouault at mines-paris.org> wrote:
> Le vendredi 02 décembre 2011 22:46:29, Jared Rubin a écrit :
>> I am looking at a few sample GeoPDF files in acrobat reader.
>> For example to retrieve the Parcel lot features from the Town of OakVille
>> example
>> http://acrobatusers.com/gallery/geospatial
>> Is this layer information available from the gdal pdf driver.
>> I have successfully built the gdal trunk using podofo and have run gdalinfo
>> on this file
> The driver will rasterize the whole layers at once. You cannot render one
> layer in particular, and there's no support for retrieving the coordinates of
> vector features.
>> Also is this available with the python binding
> Yes, but with the above limits
>> Thanks
>> Jared
