[gdal-dev] Warping without shear
Jan Hartmann j.l.h.hartmann at uva.nl
Fri Dec 16 13:50:10 EST 2011
On 16-12-2011 18:25, Joaquim Luis wrote:
> Jan,
> What you want is to apply a transformation called (at least on the
> Matlab parlance) "Linear conformal" which an afine transform but
> without the the shear terms. Mirone has it implemented and if your
> image has the GCPS embedded the operation is really simple.
Thanks Joaquim, that's exactly what I meant. How can I use Mirone's
implementation?
Jan
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111216/785f86f6/attachment.html
