[gdal-dev] GDAL/OGR 1.9.0 Beta1 Released
Kyle Shannon ksshannon at gmail.com
Wed Dec 21 14:33:16 EST 2011
I have pdftoppm:
[kyle at localhost gdrivers]$ pdftoppm -v
pdftoppm version 0.18.0
Copyright 2005-2011 The Poppler Developers - http://poppler.freedesktop.org
Copyright 1996-2004 Glyph & Cog, LLC
I can get the checksum:
[kyle at localhost gdrivers]$ gdalchksum.py data/adobe_style_geospatial.pdf
17637
17637
17637
running just the test:
[kyle at localhost gdrivers]$ python pdf.py
TEST: pdf_online_1 ... success
TEST: pdf_online_2 ... success
TEST: pdf_1 ... 16277
fail
line 164: bad checksum
Test Script: PDF
Succeeded: 2
Failed: 1 (0 blew exceptions)
Skipped: 0
Expected fail:0
Running a verbose test:
TEST: pdf_online_1 ... PDF: OGC Encoding Best Practice style detected
PDF: LGIDict Version :
PDF: This is a the largest neatline for now
PDF: CTM[0] = 3.81944e-05
PDF: CTM[1] = 0
PDF: CTM[2] = 0
PDF: CTM[3] = 3.81944e-05
PDF: CTM[4] = -77.1123283333
PDF: CTM[5] = 38.8878783333
PDF: Datum = WGE
PDF: Projection.ProjectionType = GEOGRAPHIC
GDAL: GDALOpen(tmp/cache/Cherrydale_eDOQQ_1m_0_033_R1C1.pdf,
this=0x1428660) succeeds as PDF.
PDF: Running 'pdftoppm -r 150.000000 -f 1 -l 1
"tmp/cache/Cherrydale_eDOQQ_1m_0_033_R1C1.pdf" "./pdf3968087808_0"'
PNM: PNM header contains: width=621, height=544, maxval=255
GDALRaw: RawRasterBand(0x1414230,1,0x141d100,
Off=15,PixOff=3,LineOff=1863,Byte,0)
GDALRaw: RawRasterBand(0x1414230,2,0x141d100,
Off=16,PixOff=3,LineOff=1863,Byte,0)
GDALRaw: RawRasterBand(0x1414230,3,0x141d100,
Off=17,PixOff=3,LineOff=1863,Byte,0)
GDAL: GDALOpen(./pdf3968087808_0-1.ppm, this=0x1414230) succeeds as PNM.
GDAL: GDALDefaultOverviews::OverviewScan()
GDAL: GDALClose(./pdf3968087808_0-1.ppm, this=0x1414230)
GDAL: GDALClose(tmp/cache/Cherrydale_eDOQQ_1m_0_033_R1C1.pdf,
this=0x1428660)
success
TEST: pdf_online_2 ... PDF: OGC Encoding Best Practice style detected
PDF: CTM[1] = 0
PDF: CTM[2] = 0
PDF: Datum = WGE
GDAL: GDALOpen(PDF:1:tmp/cache/Cherrydale_eDOQQ_1m_0_033_R1C1.pdf,
this=0x1408ff0) succeeds as PDF.
GDAL: GDALClose(PDF:1:tmp/cache/Cherrydale_eDOQQ_1m_0_033_R1C1.pdf,
this=0x1408ff0)
success
TEST: pdf_1 ... PDF: Adobe ISO32000 style Geospatial PDF perhaps ?
PDF: VP length = 2
PDF: Largest BBox in VP array is element 0
PDF: Subtype = GEO
PDF: Bounds[0] = 0.000000
PDF: Bounds[1] = 1.000000
PDF: Bounds[2] = 0.000000
PDF: Bounds[3] = 0.000000
PDF: Bounds[4] = 1.000000
PDF: Bounds[5] = 0.000000
PDF: Bounds[6] = 1.000000
PDF: Bounds[7] = 1.000000
PDF: GPTS[0] = 44.205359999999998877
PDF: GPTS[1] = -65.023790000000005307
PDF: GPTS[2] = 44.535930000000000462
PDF: GPTS[3] = -65.035210000000006403
PDF: GPTS[4] = 44.544530000000001735
PDF: GPTS[5] = -64.475700000000003342
PDF: GPTS[6] = 44.213870000000000005
PDF: GPTS[7] = -64.467410000000000991
PDF: LPTS[0] = 0.000000
PDF: LPTS[1] = 1.000000
PDF: LPTS[2] = 0.000000
PDF: LPTS[3] = 0.000000
PDF: LPTS[4] = 1.000000
PDF: LPTS[5] = 0.000000
PDF: LPTS[6] = 1.000000
PDF: LPTS[7] = 1.000000
PDF: GCS.Type = PROJCS
PDF: GCS.WKT =
PROJCS["WGS_1984_UTM_Zone_20N",GEOGCS["GCS_WGS_1984",DATUM["D_WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-63.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
PDF: WKT after morphFromESRI() =
PROJCS["WGS_1984_UTM_Zone_20N",GEOGCS["GCS_WGS_1984",DATUM["WGS_1984",SPHEROID["WGS_84",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Transverse_Mercator"],PARAMETER["False_Easting",500000.0],PARAMETER["False_Northing",0.0],PARAMETER["Central_Meridian",-63.0],PARAMETER["Scale_Factor",0.9996],PARAMETER["Latitude_Of_Origin",0.0],UNIT["Meter",1.0]]
OGRCT: PROJ >= 4.8.0 features enabled
OGRCT: Source: +proj=longlat +datum=WGS84 +no_defs
OGRCT: Target: +proj=utm +zone=20 +datum=WGS84 +units=m +no_defs
GDAL: GDALOpen(data/adobe_style_geospatial.pdf, this=0x1411840) succeeds as
PDF.
PDF: Running 'pdftoppm -r 200.000000 -f 1 -l 1
"data/adobe_style_geospatial.pdf" "./pdf3968087808_1"'
PNM: PNM header contains: width=1700, height=2200, maxval=255
GDALRaw: RawRasterBand(0x141b070,1,0x1374c80,
Off=17,PixOff=3,LineOff=5100,Byte,0)
GDALRaw: RawRasterBand(0x141b070,2,0x1374c80,
Off=18,PixOff=3,LineOff=5100,Byte,0)
GDALRaw: RawRasterBand(0x141b070,3,0x1374c80,
Off=19,PixOff=3,LineOff=5100,Byte,0)
GDAL: GDALOpen(./pdf3968087808_1-1.ppm, this=0x141b070) succeeds as PNM.
GDAL: GDALClose(./pdf3968087808_1-1.ppm, this=0x141b070)
16277
GDAL: GDALClose(data/adobe_style_geospatial.pdf, this=0x1411840)
fail
Test Script: PDF
Succeeded: 2
Skipped: 0
Expected fail:0
GDAL: In GDALDestroy - unloading GDAL shared library
 * Kyle Shannon
 * ksshannon at gmail.com
On Wed, Dec 21, 2011 at 11:47, Even Rouault <even.rouault at mines-paris.org>wrote:
> Le mercredi 21 décembre 2011 19:30:45, Kyle Shannon a écrit :
> > Even,
> > I rebuilt with GEOS support
> ok I'll add a test for geos presence to skip the 2 tests if it is not
> available.
> > and I added podofo support as well, for fun.  I
> > got a failure with a bad checksum in pdf.py:
> Can you just run pdf.py and look at the more precise error report. I
> believe
> it is due to missing poppler-utils ( pdftoppm namely ) that is necesserary
> to
> do the rasterization . See http://gdal.org/frmt_pdf.html
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111221/ec3f7f8d/attachment-0001.html
