[gdal-dev] GDAL/OGR 1.9.0 Beta1 Released
Even Rouault even.rouault at mines-paris.org
Wed Dec 21 13:47:15 EST 2011
Le mercredi 21 décembre 2011 19:30:45, Kyle Shannon a écrit :
> Even,
> I rebuilt with GEOS support
ok I'll add a test for geos presence to skip the 2 tests if it is not
available.
> and I added podofo support as well, for fun.  I
> got a failure with a bad checksum in pdf.py:
Can you just run pdf.py and look at the more precise error report. I believe
it is due to missing poppler-utils ( pdftoppm namely ) that is necesserary to
do the rasterization . See http://gdal.org/frmt_pdf.html
