[gdal-dev] DXF to Postgis using ogr2ogr
Ralf Suhr Ralf.Suhr at itc-halle.de
Wed Dec 28 04:07:22 EST 2011
Bob, you need a gdal version 1.8 or higher.
On Dienstag 27 Dezember 2011 19:48:33 Bob Pawley wrote:
> Something is still not penetrating this thick skull of mine.
> When I run
> ogr2ogr --config DXF_INLINE_BLOCKS FALSE  --config
> DXF_MERGE_BLOCK_GEOMETRIES FALSE  -f "PostgreSQL" PG:"host=localhost
> user=postgres dbname=db password=pass"  W_Works.dxf -overwrite
> -skipfailures  -sql "SELECT
> ST_Translate(ST_Scale(ST_Rotate((ST_Dump(b.wkb_geometry)).geom,
> e.blockangle / 180 * PI()), e.blockscale[1], e.blockscale[2]),
> ST_X(e.wkb_geometry), ST_Y(e.wkb_geometry)) AS wkb_geometry, CASE WHEN
> b.ogr_style IS NOT NULL THEN b.ogr_style ELSE e.ogr_style END AS
> ogr_style, e.layer, e.linetype, e.subclasses, b.text FROM entities e INNER
> JOIN blocks b USING (blockname)"
> I get error - Undefined function `st_dump`used.
You can not use PostGIS functions on dxf file source.
> When I run a simplified version
> -skipfailures  -sql "SELECT wkb_geometry From entities"
> I get error - unrecognized field name wkb_geometry
> In the last, when I substitute wkb_geometry for the blocks (name, angle,
> scale) or text I get no errors.
> In all of the commands I`ve run, the block table remains empty.
The dxf file contains two different ogr layers.
ogr2ogr --config DXF_INLINE_BLOCKS FALSE --config DXF_MERGE_BLOCK_GEOMETRIES
FALSE  -f "PostgreSQL" PG:"host=localhost user=postgres dbname=db
password=pass" W_Works.dxf entities
password=pass" W_Works.dxf blocks
And finaly run the sqls inside the postgis database.
> Bob
> From: Ralf Suhr
> Sent: Wednesday, December 21, 2011 1:30 AM
> To: Bob Pawley
> Cc: gdal-dev at lists.osgeo.org
> Subject: Re: [gdal-dev] DXF to Postgis using ogr2ogr
> On Import you can't use -nln option or you run ogr2ogr to times. One for
> entities layer and secound for blocks.
> ogr2ogr -f postgresql -nln myentities PG:"..." W_Works.dxf entities
> ogr2ogr -f postgresql -nln myblocks PG:"..." W_Works.dxf blocks
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20111228/9e3a52f8/attachment.html
