[gdal-dev] error adding ecw on Ubuntu 10.4 (lucid)
Matt Wilkie maphew at gmail.com
Sat Feb 5 14:18:16 EST 2011
> So you should try "sudo gdal-ecw-build /usr/local" because you "./configure"
> the ECW SDK without any installation prefix.
Ahh, thanks Even. That let me run gdal-ecw-build without error, though
there were lots of deprecation warnings.
 "gdalinfo --formats |grep -i ecw" still comes back empty however.
http://lists.osgeo.org/pipermail/ubuntu/2009-June/000054.html
indicates this should be enough, though apparently not for me. Any
other suggestions?
thanks,
-matt
