[gdal-dev] OGR Shapefile SQL with date in where clause
Nicolas Simon nicolas.simon at spw.wallonie.be
Mon Feb 7 10:08:23 EST 2011
Hello,
	I would like to extract feature from a shapefile layer based on a Date field.
	But I don't know how to format date value
	Here is a defect command
ogr2ogr -f "ESRI Shapefile" extrait.shp fulldataset.shp -sql "select * from fulldataset where VISTERRAIN = '2010/12/07' "
	Help will be welcome.
	Thank you
	Nicolas Simon
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110207/acada065/attachment-0001.html
