[gdal-dev] OGR Shapefile SQL with date in where clause
Paolo Corti pcorti at gmail.com
Mon Feb 7 10:25:47 EST 2011
On Mon, Feb 7, 2011 at 4:08 PM, Nicolas Simon
<nicolas.simon at spw.wallonie.be> wrote:
> Hello,
>         I would like to extract feature from a shapefile layer based on a
> Date field.
>         But I don't know how to format date value
>         Here is a defect command
> ogr2ogr -f "ESRI Shapefile" extrait.shp fulldataset.shp -sql "select * from
> fulldataset where VISTERRAIN = '2010/12/07' "
>         Help will be welcome.
>         Thank you
>         Nicolas Simon
Hi Nicolas
I am using gdal 1.8 and it is working for me, look at the output:
ogrinfo -al poi.shp
INFO: Open of `poi.shp'
      using driver `ESRI Shapefile' successful.
Layer name: poi
Geometry: Point
Feature Count: 3
Extent: (-5106701.348438, -1250725.685421) - (-17541.662933, 4118769.067506)
Layer SRS WKT:
PROJCS["WGS_1984_UTM_Zone_32N",
    GEOGCS["GCS_WGS_1984",
        DATUM["WGS_1984",
            SPHEROID["WGS_1984",6378137.0,298.257223563]],
        PRIMEM["Greenwich",0.0],
        UNIT["Degree",0.0174532925199433]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["False_Easting",500000.0],
    PARAMETER["False_Northing",0.0],
    PARAMETER["Central_Meridian",9.0],
    PARAMETER["Scale_Factor",0.9996],
    PARAMETER["Latitude_Of_Origin",0.0],
    UNIT["Meter",1.0]]
mydate_d: Date (10.0)
mydate_s: String (50.0)
OGRFeature(poi):0
  Id (Integer) = 0
  mydate_d (Date) = 2010/08/11
  mydate_s (String) = (null)
  POINT (-4071618.022572413086891 4118769.067506278399378)
OGRFeature(poi):1
  Id (Integer) = 0
  POINT (-5106701.348437865264714 668491.314621437806636)
OGRFeature(poi):2
  Id (Integer) = 0
  mydate_d (Date) = 2010/11/11
  POINT (-17541.662932725295832 -1250725.685420754598454)
ogr2ogr out.shp poi.shp -sql "select * from poi where mydate_d = '2010/08/11'"
ogrinfo -al out.shp
INFO: Open of `out.shp'
Layer name: out
Geometry: Point
Feature Count: 2
Extent: (-5106701.348438, 668491.314621) - (-4071618.022572, 4118769.067506)
Layer SRS WKT:
        DATUM["WGS_1984",
        UNIT["Degree",0.017453292519943295]],
    UNIT["Meter",1.0]]
OGRFeature(out):0
  Id (Integer) = 0
OGRFeature(out):1
  Id (Integer) = 0
What error do you get?
best regards
P
Paolo Corti
Geospatial software developer
web: http://www.paolocorti.net
twitter: @paolo_corti
