[gdal-dev] generate vrt from grass data
Massimo Di Stefano massimodisasha at gmail.com
Sat Feb 12 23:57:24 EST 2011
Hi All
i'm using python-gdal to generate vrt file, it works fine but for some data like  :
(from the spearfish dataset) the raster file :
spearfish60/PERMANENT/cellhd/tractids
gdalinfo give me :
http://www.geofemengineering.it/data/vrtlog.txt
tring to generate a vrt freeze my shell and i have to force quit it.
i tested it on osx 10.6.6 (gdal.framework,  grass6.5.svn)
and on linux debian sid (gdal svn , grass65 svn)
i got the same results ( ctrl+D ctrl+C doesn't work, force quit the shell)
