[gdal-dev] Re: gdal android
Mohammed Rashad mohammedrashadkm at gmail.com
Thu Feb 17 06:00:09 EST 2011
here is my new error log
cpl_strtod.cpp: In function 'void CPLReplacePointByLocalePoint(char*,
char)':
cpl_strtod.cpp:200: error: 'struct lconv' has no member named
'decimal_point'
cpl_strtod.cpp:201: error: 'struct lconv' has no member named
'decimal_point'
cpl_strtod.cpp:204: error: 'struct lconv' has no member named
'decimal_point'
make[1]: *** [cpl_strtod.lo] Error 1
make[1]: Leaving directory `/home/rashadkm/gdal-1.8.0/port'
make: *** [port-target] Error 2
Which gdal version to use for Android
On Thu, Feb 17, 2011 at 4:10 PM, Mohammed Rashad <mohammedrashadkm at gmail.com
> wrote:
> I am using android-ndk-r4-crystax. gdal is building proprerly but I am
> getting error when linking gdal with my application
> here is my error log
> /home/rashadkm/android/android-ndk-r4-crystax/build/prebuilt/linux-x86/arm-eabi-4.4.0/bin/../lib/gcc/arm-eabi/4.4.0/../../../../arm-eabi/bin/ld:
> /home/rashadkm/android/gdal/lib/libgdal.a(ogrregisterall.o): Relocations in
> generic ELF (EM: 3)
> generic ELF (EM: 3)
> generic ELF (EM: 3)
> generic ELF (EM: 3)
> generic ELF (EM: 3)
> generic ELF (EM: 3)
> /home/rashadkm/android/gdal/lib/libgdal.a: could not read symbols: File in
> wrong format
> collect2: ld returned 1 exit status
> Thanks && Regards
> Rashad
Thanks && Regards
Rashad
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110217/be23a130/attachment-0001.html
