Fwd: Re: [gdal-dev] FWTools and GDAL 1.7.0
Joaquim Luis jluis at ualg.pt
Thu Jan 6 19:25:51 EST 2011
> Perhaps that's why the standard place for Python is NOT in "Program
> Files"
Yes,  there is wisdom.
> That being said, "Program Files" does seem to work fine for me most of
> the time.
And for the (1 - "most") times that it didn't work you knew how to fix
it (enclosing the full path with "") but many people don't know it.
> By the way, isn't there some new stuff about "side by side" installs
> or something -- that's supposed to help dll hell?
I think you are referring to the "manifests" but here also MS has
changed their mind (aleluia). VC2010 doesn't have them anymore which IMO
is a compelling reason to use this compiler whenever possible.
Joaquim
