[gdal-dev] GDAL for Python 3.2 on Windows 64bit
Isaac Gerg isaac.gerg at gergltd.com
Sat Jul 9 17:57:05 EDT 2011
This sounds great.  Thanks so much Tamas.
Isaac
On Sat, Jul 9, 2011 at 5:07 PM, Tamas Szekeres <szekerest at gmail.com> wrote:
> I'm just working on to include that in the builds at
> http://www.gisinternals.com/sdk/
> Unfortunately I always have to patch the python-distutils stuff from
> versions to versions so as to make it work with all the supported
> compilers...
> Best regards,
> Tamas
> 2011/7/9 Isaac Gerg <isaac.gerg at gergltd.com>
>> Do you guys know when 3.2 will be supported?  How do I build from 3.2
>> currently using the patches you mentioned -- are there instructions
>> anywhere?
>> Thanks in advance,
>> Isaac
>> On Sat, Jul 9, 2011 at 8:28 AM, Even Rouault <
>> even.rouault at mines-paris.org> wrote:
>>> Le samedi 09 juillet 2011 13:56:54, Tamas Szekeres a écrit :
>>> > 2011/7/8 Even Rouault <even.rouault at mines-paris.org>
>>> > > http://vbkto.dyndns.org/sdk/ proposes bindings for 2.6, 2.7 and 3.1.
>>> > > Perhaps
>>> > > Tamas would want to add support for 3.2 ?
>>> > How do we stand with the Python 3.2 support in GDAL? Do we still
>>> require to
>>> > patch the gererated interface files so as to compile the bindings
>>> > successfully?
>>> > I'm a bit hesitant to include a patching step as part of the build
>>> > execution sequence.
>>> I've just downloaded the latest swig version 2.0.4 and the good news is
>>> that
>>> it now generates binding files compatible with Python 3.2 (as well as
>>> with
>>> previous Python versions). I also tested quickly with Java and Perl and
>>> the
>>> generated files are good enough to enable "make test" to run
>>> successfully.
>>> However, with CSharp, the generated cpp files have the following
>>> duplicate
>>> declaration
>>>  static OsrPINVOKE() {
>>> which causes the following error :
>>> mcs /debug:full /target:library /out:osr_csharp.dll osr/*.cs
>>> AssemblyInfo.cs
>>> osr/OsrPINVOKE.cs(192,10): error CS0111: A member
>>> `OSGeo.OSR.OsrPINVOKE.OsrPINVOKE()' is already defined. Rename this
>>> member or
>>> use different parameter types
>>> osr/OsrPINVOKE.cs(188,10): (Location of the symbol related to previous
>>> error)
>>> whereas it is ok with swig 1.3.40
>>> I couldn't find a relevant ticket in their bug tracker about this
>>> duplicate
>>> PINVOKE.
>>> > Best regards,
>>> > Tamas
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110709/7676c2ae/attachment.html
