[gdal-dev] Re: Change the spatial reference of a shapeile
Chaitanya kumar CH chaitanya.ch at gmail.com
Mon Jul 11 13:17:22 EDT 2011
Exactly.
On Mon, Jul 11, 2011 at 8:31 PM, Solimyr <giannicristian at msn.com> wrote:
> Sorry, I do not understand...You mean to write the spatialRef to a txt file
> and then doing something like:
> $ ogr2ogr  -a_srs spatialRef.txt  dst_shape.shp  src_shape.shp
> Is this what you mean? Where inside the txt file there is:
> GEOGCS["GCS_WGS_1984",
>   DATUM["WGS_1984",
>       SPHEROID["WGS_1984",637813.0,298.252223563]],
>   PRIMEM["Greenwich",0.0],
>   UNIT["Degree",0.0174532925199433]]
> Is correct?
> http://osgeo-org.1803224.n2.nabble.com/Change-the-spatial-reference-of-a-shapeile-tp6561998p6571241.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110711/e774fd69/attachment.html
