[gdal-dev] Re: GDAL unable to recognize large GRC file
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Jul 21 00:11:01 EDT 2011
John,
Can you provide me the failing file? You can send a link to me alone.
On Thu, Jul 21, 2011 at 4:24 AM, jt2000 <thakkar at nexgenwireless.com> wrote:
> Yes, I'm able to open the raster file in mapinfo.
> Turning on the CPL_DEBUG env variable produces the following.  It dosn't
> seem to help much.
> Are there any other methods I can debug this?
> The file is about 580MB.  Is there a limitation on # of pixels?
> ERROR 4: `filename.grc' not recognised as a supported file format.
> gdalinfo failed - unable to open 'filename.grc'.
> GDAL: GDALDeregister_GTiff() called.
> GDAL: In GDALDestroy - unloading GDAL shared library.
> http://osgeo-org.1803224.n2.nabble.com/GDAL-unable-to-recognize-large-GRC-file-tp6590399p6604781.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110721/a2028e36/attachment.html
