[gdal-dev] A map conversion problem with GDAL 1.8.0
Corrado Guarino Lo Bianco guarino at ce.unipr.it
Sun Jun 5 06:49:59 EDT 2011
unfortunately this did not solve the problem. I try to better describe
the problem.
In order to decide if map and dem data files are compatible,
QLandkarteGT evaluate two strings from such files according to the
following procedure
     char str[1024];
     strncpy(str,dataset->GetProjectionRef(),sizeof(str));
     char * ptr = str;
     OGRSpatialReference oSRS;
     oSRS.importFromWkt(&ptr);
     oSRS.exportToProj4(&ptr);
     strOrigProj = strProj = ptr;
if the two strings coincides the two files are considered congruent.
In the case of the two files I'm managing, the following two strings are
obtained
Map: +proj=utm +zone=32 +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m
+no_defs
DEM: +proj=utm +zone=32 +datum=WGS84 +units=m +no_defs +ellps=WGS84
+towgs84=0,0,0
As a consequence, nevertheless the two files are compatible the two
strings are different, so that dem data are rejected.
The question is: is this the only way to check compatibility between
maps and dem data or there is a better and more robust solution?
Corrado
> Corrado,
> I see that the two projections are essentially the same. You may not need
> gdalwarp after all. Try the gdal_translate utility with the -a_srs option to
> specify the Coordinate System of the output file.
> Tell us how it goes.
> On Sat, Jun 4, 2011 at 3:30 PM, Corrado Guarino Lo Bianco<
> guarino at ce.unipr.it  <http://lists.osgeo.org/mailman/listinfo/gdal-dev>>  wrote:
> >/  Hi all,
> />/  I'm a QLandkarteGT user (QLandkarteGT is based on GDAL) and I'm having a
> />/  problem related to map formats. I use ecw maps in conjunction with DEM data
> />/  stored in geotiff files. In the past I was using GDAL 1.7.2 and I had no
> />/  problems. Recently I switched to GDAL 1.8.0 and now QLandkarteGT says that
> />/  there is no matching between the projection used for the maps and that used
> />/  for DEM data, nevertheless I'm still adopting the same files. By means of
> />/  gdalwarp, I have made several unsuccessful attempts to convert DEM data into
> />/  a format suitable to be used in conjunction with ecw maps.
> />/  Can someone help me?
> />/  These are the outputs I get from the ecw and the tiff files when I run
> />/  gdalinfo:
> />/  Driver: ECW/ERDAS Compressed Wavelets (SDK 3.x)
> />/  Files: /media/IGM 25000/IGM 25.000 - Emilia Romagna.ecw
> />/  Size is 96000, 64000
> />/  Coordinate System is:
> />/  PROJCS["NUTM32",
> />/     GEOGCS["WGS 84",
> />/         DATUM["WGS_1984",
> />/             SPHEROID["WGS 84",6378137,298.257223563,
> />/                 AUTHORITY["EPSG","7030"]],
> />/             TOWGS84[0,0,0,0,0,0,0],
> />/             AUTHORITY["EPSG","6326"]],
> />/         PRIMEM["Greenwich",0,
> />/             AUTHORITY["EPSG","8901"]],
> />/         UNIT["degree",0.0174532925199433,
> />/             AUTHORITY["EPSG","9108"]],
> />/         AXIS["Lat",NORTH],
> />/         AXIS["Long",EAST],
> />/         AUTHORITY["EPSG","4326"]],
> />/     PROJECTION["Transverse_Mercator"],
> />/     PARAMETER["latitude_of_origin",0],
> />/     PARAMETER["central_meridian",9],
> />/     PARAMETER["scale_factor",0.9996],
> />/     PARAMETER["false_easting",500000],
> />/     PARAMETER["false_northing",0],
> />/     UNIT["Meter",1]]
> />/  Origin = (510000.000000000000000,5000000.000000000000000)
> />/  Pixel Size = (2.500000000000000,-2.500000000000000)
> />/  Corner Coordinates:
> />/  Upper Left  (  510000.000, 5000000.000) (  9d 7'37.99"E, 45d 9'12.26"N)
> />/  Lower Left  (  510000.000, 4840000.000) (  9d 7'26.87"E, 43d42'46.65"N)
> />/  Upper Right (  750000.000, 5000000.000) ( 12d10'40.88"E, 45d 6'33.26"N)
> />/  Lower Right (  750000.000, 4840000.000) ( 12d 6' 3.79"E, 43d40'15.39"N)
> />/  Center      (  630000.000, 4920000.000) ( 10d37'59.07"E, 44d25'17.84"N)
> />/  Band 1 Block=96000x1 Type=Byte, ColorInterp=Red
> />/   Overviews: 48000x32000, 24000x16000, 12000x8000, 6000x4000, 3000x2000,
> />/  1500x1000, 750x500, 375x250
> />/  Band 2 Block=96000x1 Type=Byte, ColorInterp=Green
> />/  Band 3 Block=96000x1 Type=Byte, ColorInterp=Blue
> />/  Driver: GTiff/GeoTIFF
> />/  Files: /media/Dati/Documenti/gps tuner/Altimetrie Italia/Emilia
> />/  Romagna/Emilia_Romagna.tif
> />/  Size is 4074, 4262
> />/  PROJCS["WGS 84 / UTM zone 32N",
> />/         PRIMEM["Greenwich",0],
> />/         UNIT["degree",0.0174532925199433],
> />/     UNIT["metre",1,
> />/         AUTHORITY["EPSG","9001"]],
> />/     AUTHORITY["EPSG","32632"]]
> />/  Origin = (499966.037957447464578,5101878.644408876076341)
> />/  Pixel Size = (80.031641738007920,-80.031641738007920)
> />/  Metadata:
> />/   AREA_OR_POINT=Area
> />/  Image Structure Metadata:
> />/   COMPRESSION=DEFLATE
> />/   INTERLEAVE=BAND
> />/  Upper Left  (  499966.038, 5101878.644) (  8d59'58.42"E, 46d 4'13.74"N)
> />/  Lower Left  (  499966.038, 4760783.787) (  8d59'58.50"E, 42d59'58.99"N)
> />/  Upper Right (  826014.946, 5101878.644) ( 13d12'35.68"E, 45d59'34.36"N)
> />/  Lower Right (  826014.946, 4760783.787) ( 12d59'42.00"E, 42d55'47.82"N)
> />/  Center      (  662990.492, 4931331.216) ( 11d 3' 3.01"E, 44d31' 0.81"N)
> />/  Band 1 Block=256x256 Type=Int16, ColorInterp=Gray
> />/  Thank you for your help,
> />/  Corrado
> />/  _______________________________________________
> />/  gdal-dev mailing list
> />/  gdal-dev at lists.osgeo.org  <http://lists.osgeo.org/mailman/listinfo/gdal-dev>
> />/  http://lists.osgeo.org/mailman/listinfo/gdal-dev
> Best regards,
> Chaitanya kumar CH.
> /t?a???nj?/ /k?m?r/
> +91-9494447584
> 17.2416N 80.1426E
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110604/0ddf02fe/attachment-0001.html
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110605/da4d529a/attachment.html
