[gdal-dev] installing ogrsf_frmts include files
Stephen Woodbridge woodbri at swoodbridge.com
Wed Jun 8 17:19:54 EDT 2011
Hi Frank et al,
Is there a way to install the ogrsf_frmts include files short of just
manually copy the files. OpenGraphRouter is using some of these in C++
to create geometries. Specifically:
   ogrsf_frmts/shape/shapefil.h
   ogrsf_frmts/kml/ogr_kml.h
and maybe some others. Since these are not normally installed, I'm
assuming this is a bad thing that we are trying to use them and should
look at some other way of defining our geometries because these are not
intended as public api and are subject change.
Thoughts? Suggestions welcome.
Thanks,
   -Steve
