[gdal-dev] openjpeg build configuration
Chaitanya kumar CH chaitanya.ch at gmail.com
Thu Mar 17 12:27:34 EDT 2011
Brian,
GDAL's JP2OpenJPEG driver is based on version 2 of OpenJPEG library.
http://www.gdal.org/frmt_jp2openjpeg.html
On Thu, Mar 17, 2011 at 9:06 PM, Brian Wilson <brian at wildsong.biz> wrote:
> I am trying to build 1.8.0 on Linux with openjpeg support.
> I can easily build and install openjpeg from source
> (oropenjpeg_v1_4_sources_r697) into /usr/local
> ./configure --with-openjpeg
> ./configure --with-openjpeg=/usr/local
> both result in
>   OpenJPEG support:          no
> I wiped my gdal-1.8.0 directory and unpacked a fresh copy to make sure
> nothing was cached.
> I can see this test in configure output
> checking for opj_decode_tile_data in -lopenjpeg... no
> which does not look promising. Is there a version compat problem?
> Brian
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
/tʃaɪθənjə/ /kʊmɑr/
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110317/00b19df0/attachment.html
