[gdal-dev] GDAL autotest (mrsid_1) crashing on Win64
Even Rouault even.rouault at mines-paris.org
Wed Mar 23 08:53:57 EDT 2011
Selon Tamas Szekeres <szekerest at gmail.com>:
Tamas,
Indeed there have been recent changes. You might want to drop a note about that
to Kirk in ticket http://trac.osgeo.org/gdal/ticket/4002 . After latest fixes
from Kirk and me, I no longer see problems under Linux however.
I don't know which version of the GeoDSDK you are using. But, at least under
Linux, there's an ABI incompatibility of GeoSDSK v7 with latest libgeotiff (due
to the addition of new fields in geo_normalize.h) that cause crashes. But the
libgeotiff change is a bit older than the MrSID driver one, so it would be
surprising that Kirk changes have an impact on that. Under Linux, using version
8 solves that issue. If you revert only the changes of the MrSID driver (to what
it was before r21974), what happens ?
Best regards,
Even
> Hi All,
> I'm experiencing permanent crash in the mrsid_1 autotest on the Win64 builds
> of http://vbkto.dyndns.org/sdk/. This problem may be related due to a recent
> change (in 2-3 days).
> Any ideas about the reason?
> Best regards,
> Tamas
