[gdal-dev] GDAL autotest (mrsid_1) crashing on Win64
Kirk McKelvey kmckelvey at lizardtech.com
Wed Mar 23 11:47:03 EDT 2011
Strange, nothing happened to the driver code in that range.  I will bring up a 64-bit build and see if I can debug it.  Am I correct that your 32-bit builds are passing this test?
________________________________________
De : gdal-dev-bounces at lists.osgeo.org [gdal-dev-bounces at lists.osgeo.org] de la part de Tamas Szekeres [szekerest at gmail.com]
Date d'envoi : mercredi 23 mars 2011 08:36
À : Even Rouault
Cc : gdal-dev
Objet : Re: [gdal-dev] GDAL autotest (mrsid_1) crashing on Win64
Even,
According to the buildlog at http://vbkto.dyndns.org/sdk/  r21980 was still OK, and r21988 was already wrong.
Best regards,
Tamas
2011/3/23 Even Rouault <even.rouault at mines-paris.org<mailto:even.rouault at mines-paris.org>>
Selon Tamas Szekeres <szekerest at gmail.com<mailto:szekerest at gmail.com>>:
Tamas,
Indeed there have been recent changes. You might want to drop a note about that
to Kirk in ticket http://trac.osgeo.org/gdal/ticket/4002 . After latest fixes
from Kirk and me, I no longer see problems under Linux however.
I don't know which version of the GeoDSDK you are using. But, at least under
Linux, there's an ABI incompatibility of GeoSDSK v7 with latest libgeotiff (due
to the addition of new fields in geo_normalize.h) that cause crashes. But the
libgeotiff change is a bit older than the MrSID driver one, so it would be
surprising that Kirk changes have an impact on that. Under Linux, using version
8 solves that issue. If you revert only the changes of the MrSID driver (to what
it was before r21974), what happens ?
Best regards,
Even
> Hi All,
> I'm experiencing permanent crash in the mrsid_1 autotest on the Win64 builds
> of http://vbkto.dyndns.org/sdk/. This problem may be related due to a recent
> change (in 2-3 days).
> Any ideas about the reason?
> Best regards,
> Tamas
