[gdal-dev] Re: Fwd: merging shapefiles larger than 4GB
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Tue May 3 11:10:10 EDT 2011
Harsha Ch <harsha.ch <at> gmail.com> writes:
> Thanks all for the replies and pointers. Jukka I am curious how were you able
to merge upto 8GB shape files
Sorry about being unclear. I was appending shapefiles into Spatialite database
instead of merging shapefiles because I met the absolut limit of 4 GB filesize
for the SHP part.  Spatialite database file worked fine till about 8 GB filesize.
-Jukka Rahkonen-
