[gdal-dev] Having trouble compiling MrSid in GDALv1.8
Kirk McKelvey kmckelvey at lizardtech.com
Tue May 17 18:51:47 EDT 2011
The line it is complaining about is almost certainly the following line, where MRSID_DIR is used for the first time.  Not sure how it gets 72.
What is your value for GDAL_HOME?  There might be some kind of quoting issue going on.  Also, I'm not sure I ever tested it with relative paths, so that could be it as well.
From: gdal-dev-bounces at lists.osgeo.org [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Paul Meems
Sent: mardi 17 mai 2011 17:19
To: gdal-dev at lists.osgeo.org
Subject: [gdal-dev] Having trouble compiling MrSid in GDALv1.8
Hi all,
I'm trying to compile GDALv1.8 on Win7 using VS2008Pro.
So far I've added successfully GEOS, cUrl, ECW, Proj.4 and Xerces.
I'm now trying to add MrSid support.
I've downloaded the Unified Decode SDK v8 from LizardTech and changed this in my nmake.opt:
MRSID_DIR =    $(GDAL_HOME)\..\LizardTech-SDK\Win32
When I compile I get an error in line 72:
fatal error U1023: syntax error in expression   \GDAL\gdal18\frmts\mrsid\nmake.opt
I didn't changed this file.
Lines 64 - 80 are:
!IF DEFINED(MRSID_DIR)
# Guard against conflicting configuration.
!IF DEFINED(MRSID_RASTER_DIR) && DEFINED(MRSID_LIDAR_DIR)
!ERROR The MRSID_DIR value is redundant or conflicts with the values of MRSID_RASTER_DIR and MRSID_LIDAR_DIR.  Please remove one of these values from the build configuration.
!ENDIF
# If a raster path was not explicitly set, see if MRSID_DIR is one.
!IF !DEFINED(MRSID_RASTER_DIR)
!IF EXIST("$(MRSID_DIR)\Raster_ESDK\include\lt_base.h")
MRSID_RASTER_DIR = $(MRSID_DIR)\Raster_ESDK
!ELSE IF EXIST("$(MRSID_DIR)\Raster_DSDK\include\lt_base.h")
MRSID_RASTER_DIR = $(MRSID_DIR)\Raster_DSDK
!ELSE IF EXIST("$(MRSID_DIR)\include\lt_base.h") || EXIST("$(MRSID_DIR)\include\support\lt_base.h")
!ENDIF
!ENDIF
Line 72 is !IF !DEFINED(MRSID_RASTER_DIR)
What do I need to do to enable MrSid?
Thanks,
Paul
[http://www.bontepaarden.nl/bontepaarden/images/newButton.png]Paul Meems
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org<http://www.mapwindow.org/>
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl<http://www.mapwindow.nl/>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110517/d9310954/attachment.html
