[gdal-dev] TIFF with different KEYS_DS
Jorge Martin jormarfe at gmail.com
Wed May 25 03:49:06 EDT 2011
Hello Frank,
I am trying to test my implementation using GDAL (GDALExtractRPCInfo), but I
do not get any RPC info from my TIFF file. I have pasted below the code I
have used to set/read and test the RPCCoefficientTag managment.
I am involved in a ESA project and my clients used to open the results with
a propietary software, tipically ENVI. I have the specification to fill
RPCCoefficientTag with the same structure defined by GDAL but I do not know
if ENVI is able to open this metadata.
#define TIFFTAG_RPCCOEFFICIENT 50844
static TIFFExtendProc _ParentExtender = NULL;
static void GTiffTagExtender(TIFF *tif)
    static const TIFFFieldInfo xtiffFieldInfo[] = {
        { TIFFTAG_RPCCOEFFICIENT,   -1,-1, TIFF_DOUBLE, FIELD_CUSTOM,
          TRUE, TRUE, (char*) "RPCCoefficient" }
    if (_ParentExtender)
        (*_ParentExtender)(tif);
    TIFFMergeFieldInfo( tif, xtiffFieldInfo,
        sizeof(xtiffFieldInfo) / sizeof(xtiffFieldInfo[0]) );
void SetTAG(){
     TIFF * tiff =
TIFFOpen("/home/jjmf/sample_images/OutputTIFF/input_tiff_2.tif", "r+");
    if (!tiff)
            cout << "Unable to open " << endl;
            exit(0);
   double adfRPCTag[92];
   adfRPCTag[0] = -1.0;  // Error Bias
   adfRPCTag[1] = -1.0;  // Error Random
   adfRPCTag[2] = 1.231;
   adfRPCTag[3] = 1.231;
   adfRPCTag[4] = 11.231;
   adfRPCTag[5] = 12.231;
   adfRPCTag[6] = 41.231;
   adfRPCTag[7] = 17.231;
   adfRPCTag[8] = 16.231;
   adfRPCTag[9] = 16.231;
   adfRPCTag[10] = 16.231;
   adfRPCTag[11] = 16.231;
   for (int i = 0; i < 20; i++) {
        adfRPCTag[12+i] = 1.25;
   for (int j = 0; j < 20; j++) {
        adfRPCTag[32+j] = 12.25;
    for (int k = 0; k < 20; k++) {
        adfRPCTag[52+k] = 13.25;
   for (int s = 0; s < 20; s++) {
        adfRPCTag[72+s] = 15.25;
  TIFFSetField(tiff, TIFFTAG_RPCCOEFFICIENT, 92 ,adfRPCTag);
  TIFFRewriteDirectory(tiff);
  TIFFClose(tiff);
void ReadTAG(){
     TIFF * tiff =
TIFFOpen("/home/jjmf/sample_images/OutputTIFF/input_tiff_2.tif", "r");
    uint16 nCount;
    if (!tiff)
            exit(0);
     double *prueba;
      TIFFGetField(tiff, TIFFTAG_RPCCOEFFICIENT,  &nCount, &prueba );
      for(uint16 i =0  ; i< nCount ; i++)
          cout << prueba[i] <<endl;
      TIFFClose(tiff);
int  gdalRead(){
    GDALAllRegister();
   GDALDataset  *m_poDataset;
   const char * pszSrcFilename =
"/home/jjmf/sample_images/OutputTIFF/input_tiff_2.tif";
    m_poDataset = (GDALDataset *) GDALOpen( pszSrcFilename, GA_ReadOnly );
    if( m_poDataset == NULL )
        cout << "Unable to open " << pszSrcFilename << endl;
        return 0;
    GDALRPCInfo sRPC;
   char ** Metadata=  m_poDataset->GetMetadata(NULL);
   if(GDALExtractRPCInfo(Metadata, &sRPC))
       cout << "Got RPCs Info" <<endl;
   }else{
       cout << "Not RPCs Info" <<endl;
   return 1;
int main(int argc, char** argv) {
   _ParentExtender = TIFFSetTagExtender(GTiffTagExtender);
    SetTAG();
    ReadTAG();
    gdalRead();
    return 0;
Many thanks,
Jorge
2011/5/24 Frank Warmerdam <warmerdam at pobox.com>
> On 11-05-24 12:25 PM, Jorge Martin wrote:
>> Many Thanks Frank, I have insert the RPCCoeffcientTag to the file.
>>             Is any comercial software that could read this TAG? In order
>> to
>> check the implementation I need open the file with a comercial software. I
>> have
>> tried with ENVI but it does not recognize the format.
> Jorge,
> You can test with GDAL.  It is commercial software since you can purchase
> commercial support for it from folks like me.  Or perhaps you mean
> proprietary?  Or perhaps you just mean respectible?
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20110525/4a70d2d5/attachment-0001.html
