[gdal-dev] Re: Wiki page about CMake for GDAL
Etienne Tourigny etourigny.dev at gmail.com
Tue Nov 1 13:05:22 EDT 2011
You need an osgeo ID which you can use to login to the trac wiki.
http://www.osgeo.org/osgeo_userid/
2011/11/1 Jayesh Chaudhary <aashishcy at gmail.com>:
> Hi Mateusz I just realized that somehow my email got stuck in my outbox.
> I like  what you have proposed. I just wanted to add one or two points. How
> can I get write permissions for the Wiki?
> Also as far as dependencies of GDAL driver's  are concerned,  we can
> probably manage them using CMake superbuild support.
> Also I wanted to point out that, I had started cmake port of gdal last year
> which is based on your work:
> https://gitorious.org/cmake-gdal
> 2011/10/24 Jayesh Chaudhary <aashishcy at gmail.com>
>> Hi Mateusz,
>> Thanks for putting this together. I will have a look today and probably
>> add things to it today/ tomorrow.
>> Best,
>> 2011/10/22 Mateusz Łoskot <mateusz at loskot.net>
>>> Folks
>>> I have started brainstorming the CMake for GDAL idea on Wiki:
>>> http://trac.osgeo.org/gdal/wiki/CMake
>>> Feel free to add your ideas, wishes, proposals, questions, etc.
>>> Try to keep it clear and structured if possible.
>>> Best regards,
>>> Mateusz Loskot, http://mateusz.loskot.net
>>> Charter Member of OSGeo, http://osgeo.org
>>> Member of ACCU, http://accu.org
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
