[gdal-dev] probles by ecw-convert (gdal_translate and expand)
Jean-Claude Repetto jrepetto at free.fr
Thu Nov 3 07:11:58 EDT 2011
Le 03/11/2011 11:23, Jan Tappenbeck a écrit :
> can andyone tell me how the command had to be for
> "Consider using color table expansion (-expand option in
> gdal_translate)" ???
This is explained in the documentation :
http://www.gdal.org/gdal_translate.html
In your case, I think you'll have to use "-expand rgb" .
BTW, if you need to obtain a georeferenced file, don't forget to use the
"-co DATUM=..." and "-co PROJ=..." options.
Jean-Claude
