[gdal-dev] Windows FWTools GDAL built with GEOS intersection support?
Mateusz Łoskot mateusz at loskot.net
Wed Nov 16 06:25:32 EST 2011
On 16 November 2011 08:31, Jean-Claude Repetto <jrepetto at free.fr> wrote:
> Le 16/11/2011 04:48, Chaitanya kumar CH a écrit :
>> Chris,
>> FWTools for Windows had not been maintained for quite a while. But the
>> Intersection() function should work with the latest. It uses gdal1.5
> Hi,
> Since FwTools is not maintained, I think the FwTools paragraph on the page
> http://trac.osgeo.org/gdal/wiki/DownloadingGdalBinaries should be removed,
> or at least put at the bottom of the page. Presently, it is misleading.
If a reader hangs on reading until the second paragraph, she will know
clearly what is the status of FWTools and what is recommended option:
"The latest FWtools version for Windows, 2.4.7, dates back to a pre-1.6 GDAL
version. In order to benefit from the latest and greatest, you can
refer to the other
binary builds mentionned in the here-after Windows section. "
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
Member of ACCU, http://accu.org
